vagen Posted September 4, 2009 Share Posted September 4, 2009 I am wondering if my FMIC will fit I don't have the car yet so I can't just walk out and measure. what I have is a 27x5.5x2.25 Ebay cooler. I'm thinking about replacing the grille with it the 27inch length is to the end of the in/outlet. If I cant replace the grille I will probably put it behind the grille. this is an RX that I'm working with Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted September 4, 2009 Share Posted September 4, 2009 There really isn't any room in either of those places and I doubt you will get it between the headlight buckets when you add the couplings for the inlet/outlet. Best option with these cars is a top mount but if you are set on a fmic the it's pretty much got to go below/behind the bumper. GD Quote Link to comment Share on other sites More sharing options...
vagen Posted September 4, 2009 Author Share Posted September 4, 2009 Darn I was hoping this would work. the grille on my rx looks like it went missing at some point. perhaps I could have the in/outlets moved to the back of the cooler. Quote Link to comment Share on other sites More sharing options...
Turbone Posted September 4, 2009 Share Posted September 4, 2009 It would have to fit under the radiator, behind the bumper/lower valence. You dont want to block ait flow to the rad, bad juju for a EA82T. Suberdave's Wagon has a FMIC, check it out. http://www.suberdave.com/subaru/Leone/index.htm Quote Link to comment Share on other sites More sharing options...
vagen Posted September 4, 2009 Author Share Posted September 4, 2009 oh well top mount it is. Quote Link to comment Share on other sites More sharing options...
zukiru Posted September 4, 2009 Share Posted September 4, 2009 you can mount it facing down if you have a way to channel air to it. Quote Link to comment Share on other sites More sharing options...
