LegacyWagon92 Posted November 5, 2009 Share Posted November 5, 2009 Message board This is a copy of part from one of the manuals that I have about teardown Piston Pin Removal Use piston pin remover 499097300 or 499097500:eek: to remove the piston pin. Insert the tool 3/4 of the way into the pin and pull the tool with the pin through the access hole. What else can I use for pin remover w/o buying a special tool? I have not even opened the oil pan or anything but the heads are off and the motor is on the bench. I want to find out before I go at it. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted November 5, 2009 Share Posted November 5, 2009 use a long enough carriage bolt and grind the tip down just enough to grab the piston pin. i have one that a friend made for me. Quote Link to comment Share on other sites More sharing options...
