installing remote entry - hard or easy?
How hard would it be to install my 98 OBW remote entry (Subaru installed system) into my 1996 Legacy LSi?
Reading through here it seems like a rather complicated.
Including the fact that it might not even be possible without the actuator which is remote-entry specific on the drivers side.
Anyone have experience doing this?
I would characterize the Subaru branded, dealer installed keyless entry our '98 OBW came with as essentially the same as an aftermarket unit. It doesn't plug into any ready-made place on the wiring harness; it's attached with vampire taps (scotchlok) connectors. Ours was intermittent, and I couldn't get any documentation for it so I just tore it out and installed an aftermarket unit.
If you just want keyless entry, all you need is:
+12V constant power
+12 (switched)
ground
Lock line
unlock line.
You can leave off all the "extra" stuff: you don't _need_ the horn, parking lights, dome lights, trunk release wires etc. The most difficult part for me was programming the new keyless entry.
I'm installing keyless entry in a Bonneville today, so we'll see if it's as simple as it was on the Subie!
Nathan
