bsoelman Posted February 9, 2010 Share Posted February 9, 2010 I have a 99 legacy Brighton. I noticed while putting speakers in it that there is wiring for the tweeters, is there also wiring in the rear doors for speakers?, because it doesnt have rear speakers. Also is the wiring there for the tach on the inst. cluster, will a cluster with a tach plug and play? Thanks Quote Link to comment Share on other sites More sharing options...
WoodsWagon Posted February 9, 2010 Share Posted February 9, 2010 Yes, tweeters and rear speakers will plug in. You will need to cut out the holes in the rear door panels and put on the speaker covers. I've done it, it takes careful work with a box cutter to get the holes right. Or, you could replace the whole door panel with one out of a donor car, but finding one with rear speakers and crank windows is harder. A tach cluster will plug in, however your odometer milage will be wrong, you will need to get a milage certified sticker put on the door post and the car will be difficult to sell. OR, you can take your cluster apart, and the donor cluster, and take out the blank tach hole cover and put the tach in. It's 3 screws through the PCB on the back that provide power, ground and signal to the tach. It's easy to do, nothing more than a phillips screwdriver required. One note about working on the cluster... there's a switch on top of the steering column. You may not have noticed it. It turns on the parking lights. When you do bump it while working on the dash, don't come back saying there's an electrical problem and you can't turn off the lights. I've de-Brightonized my dad's 95 legacy. Tach, tweeters, cd player, rear speakers, rear wiper, cruise control, outback struts, outback sized tires and alloy wheels, and a skidplate off of an older subaru. It all bolts in, plugs in, and works great. Quote Link to comment Share on other sites More sharing options...
eppoh Posted February 9, 2010 Share Posted February 9, 2010 I've de-Brightonized my dad's 95 legacy. Tach, tweeters, cd player, rear speakers, rear wiper, cruise control, outback struts, outback sized tires and alloy wheels, and a skidplate off of an older subaru. It all bolts in, plugs in, and works great. Now this interests me. I have a 98 Brighton, and would like to know about adding cruise control. How did that go for you? Quote Link to comment Share on other sites More sharing options...
WoodsWagon Posted February 10, 2010 Share Posted February 10, 2010 All the wires are there for cruise control. You need the pump, the actuator, the cable with nuts, the vacuum hoses and pipe that goes across the engine bay, the cruise control computer, the cruise control brake switch, the dash switch, and the steering wheel switch. If you pull it all out of a donor car, you'll know where it goes back in to your car. Quote Link to comment Share on other sites More sharing options...
bsoelman Posted February 10, 2010 Author Share Posted February 10, 2010 Beautiful, yeah i did the rear speakers today, not bad, next up is the cluster, then maybe I will do the cruise. Thanks much. Oh did the outback struts change the ride height or just ride quality? Quote Link to comment Share on other sites More sharing options...
idosubaru Posted February 10, 2010 Share Posted February 10, 2010 OBW struts will raise all the legacy's - Brighton, L, LSi, GT, they all sit lower to the ground. Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted February 10, 2010 Share Posted February 10, 2010 OBW struts will raise all the legacy's - Brighton, L, LSi, GT, they all sit lower to the ground. You have to get REAL outback struts though. 95 and 96 were the same as any other. 97 was the first year for the true Outback. Quote Link to comment Share on other sites More sharing options...
johnceggleston Posted February 11, 2010 Share Posted February 11, 2010 You have to get REAL outback struts though. 95 and 96 were the same as any other. 97 was the first year for the true Outback. 95 yes, but i thought 96 brought the real outback with a step roof, 2.5L engine (except with the manual trans) and taller struts / tires. Quote Link to comment Share on other sites More sharing options...
