Seantheimpaler Posted September 3, 2010 Share Posted September 3, 2010 So ive got a set of mismatched tires, they are all the same size but they have different tread patterns and wear, it looks like they put a new pair on the front. how delicate are these old soobies? will it f*&^ up my differentials if i run it in 4wd? its an 1983 wagon with hi/lo... Quote Link to comment Share on other sites More sharing options...
1-3-2-4 Posted September 3, 2010 Share Posted September 3, 2010 I'm not old school but my car for the past year or longer (got the car used) the right rear tire blew so they had a single tire put on all same size but it seems the other 3 are newer then the old tire.. No ill effects Quote Link to comment Share on other sites More sharing options...
rpholz Posted September 4, 2010 Share Posted September 4, 2010 seen someone grenade their transfer case in a f-150 cause they had street tires up front and and 32's in the rear. why they had that set-up no idea Quote Link to comment Share on other sites More sharing options...
idosubaru Posted September 4, 2010 Share Posted September 4, 2010 you'll only be running 4WD offroad, slick conditions etc, that's fine. otherwise that year should be front wheel drive when it's not 4WD right? if so, then you're golden. Quote Link to comment Share on other sites More sharing options...
Seantheimpaler Posted September 4, 2010 Author Share Posted September 4, 2010 you'll only be running 4WD offroad, slick conditions etc, that's fine. otherwise that year should be front wheel drive when it's not 4WD right? if so, then you're golden. yeah when the 4wd is disengaged its front wheel drive. so your saying as long as im not in 4wd on dry pavement (which would be pointless anyway) i will be fine? Quote Link to comment Share on other sites More sharing options...
edrach Posted September 4, 2010 Share Posted September 4, 2010 yeah when the 4wd is disengaged its front wheel drive. so your saying as long as im not in 4wd on dry pavement (which would be pointless anyway) i will be fine? Yes. You should never run in 4WD on dry pavement. The earlier cars can't deal with that since they don't have a center differential. In snow, on dirt, or mud they work just fine. Quote Link to comment Share on other sites More sharing options...
NoahDL88 Posted September 4, 2010 Share Posted September 4, 2010 Mismatched tires will increase the risk of accident, I was running DL sized 175 on the front of my DL and the previous owner installed GL sized 185's on the rear, came around a corner too fast and the rear tried to overtake the front. And thats when I learned the mighty subie was indestructable, well, except for the windsheild, but we rolled it back over and it did just fine. Cliff notes: Same size ok if not same brand, different sizes are bad m'kay Also, don't use 4x4 on dry pavement. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted September 5, 2010 Share Posted September 5, 2010 4WD is ok on dry pavement if you know what you are doing and have matching tires . With matching tires there is NO STRESS in the drivetrain from using 4WD in a straight line. When it gets sticky is turning corners and you have to take it out before you get bound up real bad. I've been using 4WD Low range 4th gear on my 4 speed for years in place of a blown 3rd that pops out, etc. You just have to remember to go back to 2nd gear 2WD for turning. Which isn't a problem in practice. I've driven like this with many Subaru transaxles and never once had a problem as long as you don't break the golden rule's of tire size/inflation and sharp turns. GD Quote Link to comment Share on other sites More sharing options...
