jimkup Posted February 16, 2004 Share Posted February 16, 2004 Are the EA82 & EA82T heads interchangeable? Are there any differences between the two heads, ie.. valves,...? Would I have to modify a Turbo head if I could install it on my non-trubo EA82? Thanks! Quote Link to comment Share on other sites More sharing options...
jimkup Posted February 16, 2004 Author Share Posted February 16, 2004 sorry guys, just did a search & got my answer. NO. MPFI & Trubo have two intake ports & SPFI (& Carb I presume) only have one port. Thanks anyway! Quote Link to comment Share on other sites More sharing options...
calebz Posted February 16, 2004 Share Posted February 16, 2004 Do you have some spare turbo heads floating around looking for a home? Quote Link to comment Share on other sites More sharing options...
jimkup Posted February 16, 2004 Author Share Posted February 16, 2004 No. I need non-turbo head(s) but was hoping that a turbo head may work. Quote Link to comment Share on other sites More sharing options...
MilesFox Posted February 16, 2004 Share Posted February 16, 2004 carb and spfi heads will interchange. but the passenger side head may have a different egr fitting. usually its on the top, but some carb heads have it near the exhaust port. driver side heads are no difference if the egr location is different, just keep the egr tube that goes to the head, since it connects to the intake in the same location(i suggest you look and compare first) Quote Link to comment Share on other sites More sharing options...
jimkup Posted February 25, 2004 Author Share Posted February 25, 2004 That's Great info.! Thanks! Quote Link to comment Share on other sites More sharing options...
