whitesti400 Posted June 28, 2011 Share Posted June 28, 2011 I Just bought a 79 brat with the single range trans and was wanting to know if the dual range is a direct swap other than the interior console and shifter? Will it swap over with the same axles and driveshaft? also are there any things i should know about these cars quirks? PS- Im new I will introduce myself and show pics soon Quote Link to comment Share on other sites More sharing options...
mcbrat Posted June 29, 2011 Share Posted June 29, 2011 most likely not if you want to keep the 1600 ea71 engine... the only Gen1 to come with a D/R was an '81 GL. and it came with a 1800 ea81 engine, along with the different engine crossmember that shifted the steering column to Rack juntion so the ea81 would work okay. you've got a top mount starter. the most commonly found D/R have a side mount starter, which means you'd need a side mount bell housing, but hose only came on the fat-case ea71, which started in 1980 I think. so if yours is the original motor, then it would be a "skinny case" ea71, and won't work.... the axles will work on either tranny. a new driveshaft would be needed I believe... Quote Link to comment Share on other sites More sharing options...
whitesti400 Posted June 29, 2011 Author Share Posted June 29, 2011 So its probably not worth swapping everything over? Is the 1800 and the dual range that much better to make it worth it? I think i can find everything out locally but i dont know much about them to know if it would be worth all the work? Quote Link to comment Share on other sites More sharing options...
mcbrat Posted June 29, 2011 Share Posted June 29, 2011 it depends on what you plan to use the Brat for... Quote Link to comment Share on other sites More sharing options...
whitesti400 Posted June 29, 2011 Author Share Posted June 29, 2011 Yeah that is true, I guess when it comes time to do something fun with it i might deal with it. i was just thinking if it was something that would swap over i could go ahead and do it. Thanks for your help man!! Quote Link to comment Share on other sites More sharing options...
biffanyus Posted June 30, 2011 Share Posted June 30, 2011 hey whitesti400 would love to see pics of your brat soon.... Quote Link to comment Share on other sites More sharing options...
biffanyus Posted June 30, 2011 Share Posted June 30, 2011 Nevermind.. Found them in the Welcome forum.... very nice.. Quote Link to comment Share on other sites More sharing options...
