Esteban32696 Posted February 27, 2004 Share Posted February 27, 2004 I have an '88 Justy, 2wd, with carb problems. It runs pretty good at speed, but will not idle. I do know that I need a thermostat. Never really warms up.Screw adjustments are not the problem. Parts stores want a ton of money for a rebuilt carb. Any other options???? Quote Link to comment Share on other sites More sharing options...
Esteban32696 Posted February 29, 2004 Author Share Posted February 29, 2004 Help ? Quote Link to comment Share on other sites More sharing options...
Skip Posted February 29, 2004 Share Posted February 29, 2004 Check to make sure the anti-diesel solenoid is getting power and is not knackered. Replace the tstat, you may have a feedback carb controlled by an ECU and if the engine temp is not up to closed loop op temp it may be causing problems. Here is a forum dedicated to to the Justy http://subarujusty.proboards20.com/ Hope this helps Quote Link to comment Share on other sites More sharing options...
