hankosolder2 Posted September 5, 2011 Share Posted September 5, 2011 Can anyone steer me in the direction of where to find these relays? (Again, '98 OBW) I had a bit of a nose around under the dash and came up empty. I did a search and didn't come up with many hits- are these relays all but bullet proof? Nathan Quote Link to comment Share on other sites More sharing options...
hankosolder2 Posted September 6, 2011 Author Share Posted September 6, 2011 Pretty please? Someone has got to know where the locations of the fuel pump and main relays are on a '98 OBW. Quote Link to comment Share on other sites More sharing options...
Rooster2 Posted September 7, 2011 Share Posted September 7, 2011 I checked on my 99 OBW, which is same car as yours. Fuse and relay panel is in the engine bay. Open the hood, it is right behind the battery above the road wheel. Fuses and relays are in a black box, marked "fuses & relays." Unlatch the clip closest to the windshield, and the box top hinges upward. I have read on this forum that there is, or are relay(s) under the dash, right above the lever that you pull to open the hood. There is an access door next to the lever, but it looks pretty small to be of much help. Hope this info helps..........Rooster2 Quote Link to comment Share on other sites More sharing options...
Cougar Posted September 7, 2011 Share Posted September 7, 2011 I think the relays located in the fuse panel under the hood are for the AC and headlights. The Main relay and fuel pump relay are located above the interior fuse panel if I remember correctly. I'm not real sure though. Quote Link to comment Share on other sites More sharing options...
jarl Posted September 7, 2011 Share Posted September 7, 2011 Yep... on front of the driver's door according to the FSM. Connector B46 Quote Link to comment Share on other sites More sharing options...
hankosolder2 Posted September 8, 2011 Author Share Posted September 8, 2011 Thanks! That looks really high up under the dash. I'll peek again. Quote Link to comment Share on other sites More sharing options...
Plate_o_Fries Posted August 3, 2016 Share Posted August 3, 2016 (edited) Hello there! I'm having a hell of a time finding my fuel relay switch. Did you ever find it? I can't quite make heads or tails of that schematic. My '98 Legacy Outback Limited (wagon) stalled out on me while I was driving home from work a couple nights ago. It'll fully crank but just won't start. I replaced my spark plugs, which was a vain effort (though probably about time to, anyway.) I want to check the fuel relay switch before I jump into the fuel tank itself to replace the pump. The pump isn't making any noise when I cycle through the ignition. I know this thread is several years old. Does anyone have any answers? Thank you! Edited August 3, 2016 by Plate_o_Fries Quote Link to comment Share on other sites More sharing options...
Cougar Posted August 4, 2016 Share Posted August 4, 2016 Make sure the fuses under the hood and in the dash fuse panels are okay. The main relay and fuel pump relay are under the passenger side kick panel. Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted August 4, 2016 Share Posted August 4, 2016 (edited) These pumps are hard to hear, and rarely fail. Pull the fuel line off of the filter under the hood and stick it in a bottle, see if any fuel squirts out when you turn the key On. I would also check the connector for the fuel pump on top of the sender unit before trying to get to the relay. If there is any corrosion there, its common for the terminals to burn and cause a bad connection. Edited August 4, 2016 by Fairtax4me Quote Link to comment Share on other sites More sharing options...
ocei77 Posted August 4, 2016 Share Posted August 4, 2016 There are actually three relays that control the fuel pump. The actual fuel pump relay is cylindrical and tucked up on the drivers side in a metal clip. May be white or green in color. In the engine panel SBF 2 controls juice to the fuel pump relay. However, SBF 4 controls juice to SBF 2. Check both, more often than not, it's one of these that has blown. O. Quote Link to comment Share on other sites More sharing options...
