211 Posted September 30, 2011 Share Posted September 30, 2011 2000 OBW 5mt I'm about to change the fluid in my Trans and front and rear diff's. Can someone please verify the oil weights and volumes are correct? Trans 75W-90 4.2 US Qts Rear Diff 75W-90 0.8 US Qts ...and the trans and front diff share the same oil correct? Also, the FSM calls for "Fluid Packing" on the threads for the rear diff drain plugs. What should I use? Quote Link to comment Share on other sites More sharing options...
86subaru Posted September 30, 2011 Share Posted September 30, 2011 sound about right, drain fill tranny twice , drain into gal jug then you know how much you got out each time, 1/2 in rachet fits rear diff, bottom drains it top plug fills it , Quote Link to comment Share on other sites More sharing options...
johnceggleston Posted September 30, 2011 Share Posted September 30, 2011 no need to drain and fill twice on a manual trans, once will do it just fine. and when you do the rear diff, remove the fill plug FIRST. you don't want to drain it and then find out you can't fill it. Quote Link to comment Share on other sites More sharing options...
