littlefish Posted February 15, 2012 Share Posted February 15, 2012 boring topic, sorry, but i have this radio left over from a yard sale. would like to wire it up for garage sound. i suppose power leads are a good start, can test out for speakers after that. from a '95 saturn. thanks. Quote Link to comment Share on other sites More sharing options...
tractor pole Posted February 15, 2012 Share Posted February 15, 2012 I would need to see pics to be certain but you can buy a harness that will plug into the radio that is just like the one in the car look for Metra part# 71-1858 http://www.metraonline.com/part/71-1858 it is the standard GM 21 pin plug, it was used from 1988 to 2005, you might even be able to get one from a junk yard for a couple bucks. you will also want a gm antenna plug adapter and antenna if you are planning on listening to AM radio, or you can stick a wire in the antenna and get fm. or if you want to solder connections on at the radio... these are the same as the saturn radio connections. http://www.andylphoto.com/fiero/wiring.html Quote Link to comment Share on other sites More sharing options...
