phase1/phase2 timing belt swap.
Can I use a phase1 2.2 timing belt kit for a phase2 sohc 2.5?
yes if you swap the Phase I 2.2 heads onto the Phase 2 block. but while i've done Phase I and Phase II swaps like that you need to proceed carefully due to clearance issues.
but normally - no, like capnr mentioned the belts are different.
you can use the Phase I tensioner on the Phase 2 block if you get the bracket that the tensioner bolts to - those are just attached to the block via a couple bolts. swap bracket and you can swap tensioner.
I have a few of these "kits" PM me if interested. I prefer the old style more reliable tensioner myself.
