98 OBW part out..what can fit on my 02 forester?
Yes switching the condensor would be a lot of work most likely because it wouldn't necessarily bolt up the same way as the old. Are you sure it is your compressor that is bad on the '02? If the system pressure is low, i.e. a leak somewhere, it will not turn the compressor on.
Forget the MAF, your '02 does not have a MAF, it is MAP speed density based.
