86subaru Posted November 27, 2012 Share Posted November 27, 2012 ok found a key way [ half moon] is it possible to put key in with out removing radiator 95 impreza a/t 2.2 ? Quote Link to comment Share on other sites More sharing options...
cal_look_zero Posted November 27, 2012 Share Posted November 27, 2012 ok found a key way [ half moon] is it possible to put key in with out removing radiator 95 impreza a/t 2.2 ? Just pull the fans. 95 should be 2 bolts on top for each one, and the connector at the bottom. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted November 27, 2012 Share Posted November 27, 2012 yes Quote Link to comment Share on other sites More sharing options...
86subaru Posted November 27, 2012 Author Share Posted November 27, 2012 removing the fans will give me enough room to put in the keyway [ half moon] ? Quote Link to comment Share on other sites More sharing options...
davebugs Posted November 27, 2012 Share Posted November 27, 2012 You'll have room to install it. IMO NOT enough room to fix the actual crankshaft. I pull the engine to fix the keyway. Quote Link to comment Share on other sites More sharing options...
86subaru Posted November 28, 2012 Author Share Posted November 28, 2012 got it ,, after alittle tapping , thanks Quote Link to comment Share on other sites More sharing options...
