xbeerd Posted December 4, 2012 Share Posted December 4, 2012 Can i use my EJ25 Intake manifold on the ej22e? They look the same, cept the ej22 one has an extra hose barb on the manifold i dont know where it goes to. ej25d is from 99 Legacy GT Quote Link to comment Share on other sites More sharing options...
Numbchux Posted December 4, 2012 Share Posted December 4, 2012 2.5 intake manifold ports: 2.2 Quote Link to comment Share on other sites More sharing options...
idosubaru Posted December 4, 2012 Share Posted December 4, 2012 No. EJ25 bolts are all in a line and EJ22 bolts are offset, like chux picture shows. Quote Link to comment Share on other sites More sharing options...
xbeerd Posted December 4, 2012 Author Share Posted December 4, 2012 well that solves that question, thanks guys! wish i would have thought to look at the gasket pictures like that. Quote Link to comment Share on other sites More sharing options...
Gloyale Posted December 7, 2012 Share Posted December 7, 2012 Swap the 2.2 intake wiring, and throttle body onto the 2.5 manifold. Hmm..... actually......99 DOHC 2.5 from a Legacy GT should actually be plug and play into a 95 Legacy. Quote Link to comment Share on other sites More sharing options...
WoodsWagon Posted December 9, 2012 Share Posted December 9, 2012 The extra hose barb is probably for the EVAP canister, which was mounted by the air filter box on the earlier ones, and under the back of the car on the later ones. If you loop a hose between the two nipples sticking out over there it redirects the vacuum to the third nipple over by the fuel lines just like how it works on the later cars. Quote Link to comment Share on other sites More sharing options...
xbeerd Posted December 9, 2012 Author Share Posted December 9, 2012 thats funny that you stated that, i was just reading something about that and did it. so the hose run, starts at the solenoid valve under the IM, goes thru the smaller metal line loops to the other line and that exits by the fuel lines. Quote Link to comment Share on other sites More sharing options...
