Jeff88DL Posted December 12, 2012 Share Posted December 12, 2012 I just replaced my very rusty rear door/hatch on my wagon '92 wagon with a mint condition hatch from an '86. Everything lined up fine including the wiring, locks, struts, weather stripping etc. The wind deflector mounting holes were off by 1/2" its pretty much the only difference. The only problem is my dash light is on indicating the hatch is open when its closed. Its a bit annoying while driving at night, also the cabin light stays on! If anyone knows where the sensor is located, it would help me out a ton! Thanks, Jeff Quote Link to comment Share on other sites More sharing options...
Jeff88DL Posted December 12, 2012 Author Share Posted December 12, 2012 Found it. 2 wires going to the latch mechanism behind the trim. I just cut them and now there is no more dash light indication. Not ideal, but I'm happy. Conversation with myself. End of thread. 1 Quote Link to comment Share on other sites More sharing options...
03Foxtrot Posted May 19, 2015 Share Posted May 19, 2015 Jeff, I just found your post, mine was doing the same thing and the Chiltons manual was no help. I had pulled the trim panel but was not sure what to check. I will unplug it, thanks for the post. Kris Quote Link to comment Share on other sites More sharing options...
Gloyale Posted May 20, 2015 Share Posted May 20, 2015 The switch is in the latch. Remove latch and clean switch usually solves issues. If not replace latch. Quote Link to comment Share on other sites More sharing options...
