Dual range electrical wiring question
when i converted my original S/R push button 4WD to a dual range i connected everything but the two "mystery" wires and had no issues with not having the 2 mystery wires connected, just capped them off and to this day there just doing that.. nothing. if they are for the neutral safety switch wich light does it use? if anything it would just be a complete circut for the switch maybe? hope this helps. i even went the extra step since the 4wd low light is not connected on a stock loyale without the D/R 4wd transmission from the factory. we went through pulled the instrument cluster out tapped into the 4wd low light and ran constant power through the keyed power supply. everything works great even without the 2 mystery wires connected.
hope this helps you some>
