nipper Posted December 29, 2012 Share Posted December 29, 2012 Well I have put 600 miles on Blu2 (2005 Outback Ltd 175K). I have found pennies all over the place making rattles Solved that. Upgraded the Stereo to an 09 so i can have Bluetooth. Flushed and replaced the brake pads. Replaced the rear struts, they were giving me whiplash. But one thing i cant find whoo whoo whoo No rhyme or reason to it. It sounds like it is coming from the back of the car. I cant tell you if it happens when it is warm outside, as it hasnt been warm outside. The only thing I can think of is the EVAP system. No CEL, no performance issues, just a very quiet WHOO that i cant hide with the stereo because i know an owl is mocking me. Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted December 29, 2012 Share Posted December 29, 2012 maybe try leaving the gas cap off and see if there's a change? might implicate or exonerate the evap system. IIRC, the canister and purge valve are back there. i dunno, might just need to turn your amp up to 11. Quote Link to comment Share on other sites More sharing options...
nipper Posted December 29, 2012 Author Share Posted December 29, 2012 It is one of those noises that no matter what the stereo is turned up to (i need an amp btw) you know it is there just haunting you. For the record someone else has heard it so i know it isnt just me who fell off a limb. Quote Link to comment Share on other sites More sharing options...
Ricearu Posted December 29, 2012 Share Posted December 29, 2012 I have had an old rear strut make that noise before Quote Link to comment Share on other sites More sharing options...
nipper Posted December 29, 2012 Author Share Posted December 29, 2012 Just replaced them. And the car wol hoot when moving and not moving, more so in reverse then forward, more so low speed then high speed .... Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted December 29, 2012 Share Posted December 29, 2012 Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted December 29, 2012 Share Posted December 29, 2012 Texan beat me to it, but I'm gonna post it any way. Owls? Parking brake still a drum on the rears or does your car have the integrated calipers? Quote Link to comment Share on other sites More sharing options...
rverdoold Posted December 29, 2012 Share Posted December 29, 2012 Front struts? maybe. Could be serpentine belts as well, you can try driving without and see if it is gone. Quote Link to comment Share on other sites More sharing options...
987687 Posted December 29, 2012 Share Posted December 29, 2012 Just replaced them. And the car wol hoot when moving and not moving, more so in reverse then forward, more so low speed then high speed .... So you're saying the car will make this noise when it's completely stopped? Stopped when in park or in gear? When you're driving, will it do it all the time, or just accelerating or decelerating? Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted December 29, 2012 Share Posted December 29, 2012 Interesting! ... Your car makes that Noise while is Stopped! ... ... Could I Ask if you hear that Sound with the Stereo Off? ... Could be the Stereo itself... Somehow... Quote Link to comment Share on other sites More sharing options...
ivans imports Posted December 29, 2012 Share Posted December 29, 2012 let the poor owl outa the back allready my gess whould be exhaust or sway bar links on rear Quote Link to comment Share on other sites More sharing options...
johnceggleston Posted December 29, 2012 Share Posted December 29, 2012 my 02 has an eehhh, eehhh, sound. i traced it to the toe-in (i think) adjustment bolts on the rear cross member. they ride in a rubber bushing of some kind. the noise is usually triggered by a up down movement , but fore and aft maybe could cause it too. (it is the bolt on the diagonal brace that goes from the cross member to the hub housing.) just a thought. i don't even know if 05s have a similar setup. Quote Link to comment Share on other sites More sharing options...
nipper Posted December 29, 2012 Author Share Posted December 29, 2012 STero off, heck tereo physically removed it makes the noise. I cant really tell its source yet, though i am leaning towards the Power Brake booster. Brakes are fine (i think as this car is still new to me). Otherwise it is the fuel pump, evap system, or owls Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted December 29, 2012 Share Posted December 29, 2012 (edited) while your troubleshooting, we'll watch popo-chan; Edited December 29, 2012 by 1 Lucky Texan Quote Link to comment Share on other sites More sharing options...
nipper Posted December 29, 2012 Author Share Posted December 29, 2012 while your troubleshooting, we'll watch popo-chan; hehe Quote Link to comment Share on other sites More sharing options...
nipper Posted January 15, 2013 Author Share Posted January 15, 2013 (edited) no owls at highway speeds. i think i have two, one in the dash and one in the back of the car. Edited January 16, 2013 by nipper Quote Link to comment Share on other sites More sharing options...
ivans imports Posted January 15, 2013 Share Posted January 15, 2013 have been doing alot of the rear leading arm front bushing latly kick the tire from back and see if and movment have had some realy bad ones up to a inch of movement alows the wheel to move when the brakes are applyed Quote Link to comment Share on other sites More sharing options...
nipper Posted January 16, 2013 Author Share Posted January 16, 2013 (edited) No owels once the car has warmed up either. When it is cold, and you shift into neutral the owls silence too when backing out of the driveway. They are also are there in drive. i am leaning towards a vacume source, but not much back there behind me except the EVAP system Edited January 16, 2013 by nipper Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted January 16, 2013 Share Posted January 16, 2013 How about an exhaust hanger? Or exhaust pipe or heat shield rubbing something? Quote Link to comment Share on other sites More sharing options...
nipper Posted January 16, 2013 Author Share Posted January 16, 2013 It is more ghostly then mechanical in sound. Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted January 16, 2013 Share Posted January 16, 2013 No owels once the car has warmed up either. When it is cold, and you shift into neutral the owls silence too when backing out of the driveway. They are also are there in drive... Bad Motor and /or Transmission Mounts? ... If they let enough movemento to Rub somewhere, it "could" be the source. I Kindly suggest you to do an inspection of the parts under the Car. Kind Regards. Quote Link to comment Share on other sites More sharing options...
86BRATMAN Posted January 16, 2013 Share Posted January 16, 2013 Rubbing rear brake pads or ebrake shoes? My nephew's eclipse does the same type noise, but it started after him and my brother adjusted his ebrake cables a few months ago. Quote Link to comment Share on other sites More sharing options...
nipper Posted January 16, 2013 Author Share Posted January 16, 2013 i am starting to think it may be mechanical in source. Weather will be sour for a while before i can investigate it some more Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted January 16, 2013 Share Posted January 16, 2013 Exhaust is easy to check. Just kick the tail pipe a few times. Quote Link to comment Share on other sites More sharing options...
nipper Posted January 16, 2013 Author Share Posted January 16, 2013 its this fancy shmantzy dual exhuast thing Quote Link to comment Share on other sites More sharing options...
