Subarutex Posted January 8, 2013 Share Posted January 8, 2013 I'm finally hooking up the diff lock in my RX trans I swapped into my GL Wagon. Anybody have any pinouts of the solenoids and switch, or a schematic on how you've done it? NEED to get this done ASAP Quote Link to comment Share on other sites More sharing options...
Numbchux Posted January 8, 2013 Share Posted January 8, 2013 I had a wiring diagram.....but it's pretty simple. The switch is just a double throw. switched 12v in, then out one way or the other, straight to one wire on each of the solenoids, other wire to the ground. I set mine up with relays, but once I got it set up, I tested the draw on it, and it was only a couple amps. Quote Link to comment Share on other sites More sharing options...
Caboobaroo Posted January 8, 2013 Share Posted January 8, 2013 I used to have it on my webshots account but somehow it's gone? I have a FSM you could borrow Quote Link to comment Share on other sites More sharing options...
