Responsible Jon Posted January 25, 2013 Share Posted January 25, 2013 I got an 88 GL10 Turbo wagon with 5mt and locking center differential. Using the information on gears found here, calculated my stock gearing and the gearing for this 5 speed. .871*3.7= 3.2227 -Turbo gearing .855*3.9=3.4515 -stock 82 gearing So putting this transmission into my 82 Brat would decrease my RPMs to go the same speed in top gear, correct? I know it the turbo has 25 spline stubs, can the shafts be swapped out to the 23 spline stubs from my 4 speed? Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted January 25, 2013 Share Posted January 25, 2013 I know it the turbo has 25 spline stubs, can the shafts be swapped out to the 23 spline stubs from my 4 speed? No. You can't swap stubs on MT's without splitting them open and I am not entirely sure that 4 speed stubs would work. 5MT stubs (right up through EJ stuff) would definitely work. You can build custom axles but unless you want to spend a lot of time at the junk yard trying to piece things together you will need to buy 4 axles from one of the "new" axle manufacturers like EMPI and swap the inner joints around. Factory axles use too many joint/shaft sizes and most cars of that vintage have such a mish-mash of axles in them that there's no telling what will fit - thus the easiest way is to buy 4 new axles - 2 EA81 and 2 Impreza and swap the inner joints. GD Quote Link to comment Share on other sites More sharing options...
Gloyale Posted January 26, 2013 Share Posted January 26, 2013 your #'s are off just a tad. Here you go 5spd turbo FT4wd= .871 x 3.7 = 3.2227 82 4spd D/R 4wd= .885 x 3.9 = 3.4515 And for comparison 5spd N/A 5mt S/R or D/R 4wd= .781 x 3.9 = 3.0459 So actually you would get better top end gearing out of a Stock EA82 5spd, single or dual range. And they have 23spline stubs so no probs with axles in your brat. You won't have the FT4wd:-\ FWIW, you can put 23 spline stubs into a Turbo 5spd, but you will have to split the case. Quote Link to comment Share on other sites More sharing options...
ShawnW Posted January 28, 2013 Share Posted January 28, 2013 Ive swapped the stubs and would do it again in a heartbeat if it was an EA81 car. Not needing a custom axle is enough for me and I share space with my friend and axle rebuilder Marshall Wolf who is known around here as MWE (Now FW Enterprises). Being able to replace one when I am away from home is the big thing. Quote Link to comment Share on other sites More sharing options...
