Ground wire kits
Guest taprackready
Its kinda like snake oil salesmen back in the 1700's. Supposedly a fix all cure for anything wrong with your car. Get real, quicker throttle response, higher top end power all from ground straps.
If you have a grounding problem then save your $50-$80 bucks on that kit and make your own straps from 4 guage wire you can buy from a sterio shop.
Bill
I agree with taprackready. It can help though...I noticed smoother idle and less dimming lights on my old civic, have not tried it on the sube yet
Make sure you at least run a wire from each head to the chassis and a couple off the battery to the chassis too
