Subarunner Posted June 5, 2004 Share Posted June 5, 2004 Hey Subadudes! I'm wrapping up an 86' GL10 Wagon, 3sp auto to 5sp d/r conversion. Which wires do I jumper (or hook up to the clutch pedal switch) to activate the neutral safety? Thanks Have Fun! SubaRunner Quote Link to comment Share on other sites More sharing options...
mr.radon Posted June 5, 2004 Share Posted June 5, 2004 I wouldn't bother, but you can take a stop light switch, run the "P" and "N" wires from the Transmission connector to the switch. Make it so the switch is closed only when the clutch is pressed. This is the way I was going to wire it up for my kid, but I figure if he keeps starting it in gear he'll learn how to replace a clutch or flywheel or starter. The young muct learn someday. When you pull off the shift tower and you do not re-wire the gear selector switch you need to reattach it to get the car to start since the neutral interlock runs through this breakout. It is very clear when you have the switch in your hand, you don't even need a pin out diagram. Quote Link to comment Share on other sites More sharing options...
calebz Posted June 6, 2004 Share Posted June 6, 2004 I just did the swap last year. Can't remember what color the wires were. WIll check later tonight or tomorrow. Quote Link to comment Share on other sites More sharing options...
