JWX Posted October 16, 2004 Share Posted October 16, 2004 I can't get the piston back in. I want to put new(ish) pads in and I can't get the piston in. I've never had a car fight me like this, I don't understand. what am I doing wrong? I am loosing the bleeder screw, turning the piston clockwise, pressing in on it. am I missing something? I don't have the tool for this but I will in the morning. just wanted to see if I'm doing something wrong. edit- the car is my 88 RX Quote Link to comment Share on other sites More sharing options...
Frank B Posted October 16, 2004 Share Posted October 16, 2004 Sounds right, keep trying. Quote Link to comment Share on other sites More sharing options...
Spector303 Posted October 16, 2004 Share Posted October 16, 2004 I can't get the piston back in. I want to put new(ish) pads in and I can't get the piston in. I've never had a car fight me like this, I don't understand. what am I doing wrong? I am loosing the bleeder screw, turning the piston clockwise, pressing in on it. am I missing something? I don't have the tool for this but I will in the morning. just wanted to see if I'm doing something wrong. edit- the car is my 88 RX They can be stubborn I know - I always use a squirt of WD40 around the piston and then use a 'G' clamp (Dont know what you Americans call it) to wind the piston back into the caliper assembly which seems to work well - oh and don't forget to remove the brake fluid reservoir cap to relieve a potential fluid lock sitaution and it also means you don't have to loosen off the bleed nipple and lose fluid - loosening the bleed nipple can also introduce air into the system but i'm sure you already know this. Good luck. Spector 303 England UK. Quote Link to comment Share on other sites More sharing options...
monstaru Posted October 16, 2004 Share Posted October 16, 2004 we call it a c-clamp...thats funny .g-clamp,c-clamp. sorry.oh yeah, you are doing it right.if at first yo9u don't succeed try "screwing" it back in with a clockwise motion using pliers.that has worked for me before.special tool or no special tool this job can suck..good luck man Quote Link to comment Share on other sites More sharing options...
