J DUFUR Posted October 21, 2004 Share Posted October 21, 2004 Hello I live on St. John in the US Virgin Islands. I moved down here and brought our 1997 Outback with us. From reading these posts it seems that I need a new Duty C Solenoid. Problem is that there is no Subaru dealer here anymore. This dealer still works on Subarus' and has offered to work on the car if I get the parts. I need a list of necessary parts to buy and if possible a source. Thanks. Quote Link to comment Share on other sites More sharing options...
Legacy777 Posted October 21, 2004 Share Posted October 21, 2004 here's the service procedure http://www.main.experiencetherave.com:8080/subaru_manual_scans/1999_Legacy_FSM/3_Transmission_and_Differential_Section/3-2_Automatic_Transmission_and_Differential/MSA5TCD99L187.pdf As for parts. If it's just the duty c solenoid, then all you'll need is that and probably an o-ring. Are you absolutely sure your problem is with the duty c solenoid? Have you tested it to make sure it's open/broken? here's the testing procedure for the duty c solenoid http://www.main.experiencetherave.com:8080/subaru_manual_scans/2002_WRX_FSM/scans/2002_wrx_dutyc_sol_testing.pdf It's for the 2002 wrx, but the procedure and connectors are the same. Quote Link to comment Share on other sites More sharing options...
