oregonloyale Posted August 29, 2003 Share Posted August 29, 2003 Alright , its friday and Im gonna finally attack this valve clatter head on! I have my new T belts, MM ring , O ring and the ring for the oil pump shaft. Wish me luck , cause all the other fixes did nothing, I.E. flushing, 20w50 w MMO , check valve springs.:madder: Quote Link to comment Share on other sites More sharing options...
EmmCeeBee Posted August 29, 2003 Share Posted August 29, 2003 Yeh, good luck!!!! Not that you'll need it for the T-belt, oil pump work -- just takes a few hours of wrenching. But good luck on hitting the cure for the lifter noise. One other thing I find indispensible for this work. No air compressor, so I always have a few cans of "air blaster" (like you get at Radio Shack) on hand. After solvent cleaning, you want to keep crud off the work area..... and for making sure bolt holes and mating surfaces are free of grit. Keeps the cat away from my tools, too -- Mark Quote Link to comment Share on other sites More sharing options...
