subynut Posted May 19, 2005 Share Posted May 19, 2005 Ok, this is getting rediculous. While I'm doing my sister's brakes, I notice the right rear strut would sqeak every time I touched it. Found out that the bushings are toast. I finally found the clunk when you go over bumps. Now, either the parts stores dont know what I'm talking about or they just don't have such a thing: It's hanging like this: If I push up on it, it looks like this: Anything that's rubber is considered shot in AZ, so the junkyards are out. Any sugestions? Quote Link to comment Share on other sites More sharing options...
GLCraig Posted May 19, 2005 Share Posted May 19, 2005 Remove the assembly and see if the nut that should be at the end of the strut rod is still there or just loose. Quote Link to comment Share on other sites More sharing options...
torxxx Posted May 19, 2005 Share Posted May 19, 2005 the nut that holds the mount to the strut musta backed off. You may be able to tighten up the nut,. but most likely, its bend or broke. get a used strut from a JY or from a parts car and you'll be set Quote Link to comment Share on other sites More sharing options...
subynut Posted May 19, 2005 Author Share Posted May 19, 2005 Ok, I'll check it out. Thanks! Quote Link to comment Share on other sites More sharing options...
