1he1m8 Posted June 25, 2005 Share Posted June 25, 2005 Hi, I'm living outside the state and in my country i have 93' brat.... they continue produse it till 94'-95'.... So, My question is : can i change 2wd to 4wd ??? what is the necessary parts ? does someone know a kit for it ? thanks a lot... Quote Link to comment Share on other sites More sharing options...
MilesFox Posted June 25, 2005 Share Posted June 25, 2005 4wd will bolt right in. as long as you have all the parts. i wonderif the rear suspension tube will have4 the mount for a diff? in the states brats came as 4wd only and only one year for an automatic, up until 87 is yours fwd 5spd or automatic? Quote Link to comment Share on other sites More sharing options...
1he1m8 Posted June 26, 2005 Author Share Posted June 26, 2005 Thanks for ans..... i have 5spd. and do you know what are all the parts ? and where can i get them ? do you know someone who did it ? what about kit ? 4wd will bolt right in. as long as you have all the parts. i wonderif the rear suspension tube will have4 the mount for a diff? in the states brats came as 4wd only and only one year for an automatic, up until 87 is yours fwd 5spd or automatic? Quote Link to comment Share on other sites More sharing options...
MilesFox Posted June 26, 2005 Share Posted June 26, 2005 i have done the conversion myself to a wagon along with the tranny you will need the flywheel and clutch that goes to it, along with the 2 piece driveshaft. you willeither have to fabricate a mount for the 2 piece driveshaft or shorten a driveshaft from a 4spd model if your car is a 2wd 5spd your existing tranny crossmember will work. if its an automatic, you need to find a crossmember from another brat or wagon or hatchback of that body style(4 headlights) you will need the entire rear suspension assembly from a 4wd brat, wagon, or hatch of the same body. or you can fabricate a mount for the diff on your existing suspension, and swap in 4wd trailing arms. you will also need a differential and crossmember with a 3.9 final gear ratio, the ratio will be on a tag on the back of the diff its more economical to grab the entire rear suspension, diff and all of a donor vehicle your existing clutch cable will work you may have to beat the tranny tunnel in a little but, or put spacers on the crossmember mounts to drop the tranny down a half inch or so to clear, as its a tight fit you may also have to trim the shifter hole up a little to make toom for 5th and reverse. Quote Link to comment Share on other sites More sharing options...
1he1m8 Posted June 27, 2005 Author Share Posted June 27, 2005 Thanks alot !!! I looked at your wagon and it looks very cool !!! i'll update the furom if after i'll try this convertaion.... i have done the conversion myself to a wagon along with the tranny you will need the flywheel and clutch that goes to it, along with the 2 piece driveshaft. you willeither have to fabricate a mount for the 2 piece driveshaft or shorten a driveshaft from a 4spd model if your car is a 2wd 5spd your existing tranny crossmember will work. if its an automatic, you need to find a crossmember from another brat or wagon or hatchback of that body style(4 headlights) you will need the entire rear suspension assembly from a 4wd brat, wagon, or hatch of the same body. or you can fabricate a mount for the diff on your existing suspension, and swap in 4wd trailing arms. you will also need a differential and crossmember with a 3.9 final gear ratio, the ratio will be on a tag on the back of the diff its more economical to grab the entire rear suspension, diff and all of a donor vehicle your existing clutch cable will work you may have to beat the tranny tunnel in a little but, or put spacers on the crossmember mounts to drop the tranny down a half inch or so to clear, as its a tight fit you may also have to trim the shifter hole up a little to make toom for 5th and reverse. Quote Link to comment Share on other sites More sharing options...
