idosubaru Posted June 26, 2005 Share Posted June 26, 2005 anyone install an aluminum crank pulley on their 2.2? didn't find anything in a search, surely someone has tried these out. see them all over ebay, but i don't want one that's underdriven. Quote Link to comment Share on other sites More sharing options...
Legacy777 Posted June 26, 2005 Share Posted June 26, 2005 Yeah I have an aluminum stock sized crank pulley. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted June 26, 2005 Author Share Posted June 26, 2005 the one on your website is underdriven (smaller than stock size). did you experience any low charging, power steering or a/c issues with the smaller pulley? the smaller crank pulley reduces the rpm's of these associated pulleys. Quote Link to comment Share on other sites More sharing options...
Legacy777 Posted June 26, 2005 Share Posted June 26, 2005 I've since replaced the underdriven one with a stock sized one. It's an N1 pulley http://www.imprezars.com/pulleys.htm#pulley Quote Link to comment Share on other sites More sharing options...
idosubaru Posted June 27, 2005 Author Share Posted June 27, 2005 why did you go from the underdriven pulley to a stock sized one? Quote Link to comment Share on other sites More sharing options...
Legacy777 Posted June 27, 2005 Share Posted June 27, 2005 I put a HO alternator in my car. The HO alternator does not make as much amperage at lower rpms compared to the stock alternator, so I wanted to eliminate any light dimming issues. I also purchased a smaller diameter alternator pulley to over drive the alternator. When I first purchased the unorthodox underdrive pulley, I didn't have any light dimming issues. However as the alternator aged, I did notice it a little bit. Quote Link to comment Share on other sites More sharing options...
Commuter Posted June 27, 2005 Share Posted June 27, 2005 Not what your questions asks, but I have a lightweight stock sized pulley on my 97 OB (2.5L auto). Effects? Negative - Bit more engine rocking. It caused a car vibration at times when sitting at a stop light. Not bad, but enough to bother me. Shortly after, I had the newer liquid filled engine mounts put in. (Other work was being done.) Solved that problem. Positive - Just a "hint" quicker engine acceleration. It was noticable for the first few take offs from stop lights. But then, I was expecting it too, so it might have been a placebo effect. Could I tell the difference in a blind test, repeatedly? I rather doubt it. Commuter Quote Link to comment Share on other sites More sharing options...
idosubaru Posted June 27, 2005 Author Share Posted June 27, 2005 thanks for the feedback all. i like solid pulleys better than harmonic balancers as the rubber ring can fail and i hate failure points. i'll take the minor vibrations. i'm hoping a PRO ECM pulley is well balanced. i know a few others running PRO ECM pulleys on other soobs and never heard them mention vibration issues. Quote Link to comment Share on other sites More sharing options...
Commuter Posted June 28, 2005 Share Posted June 28, 2005 i know a few others running PRO ECM pulleys on other soobs and never heard them mention vibration issues. Just to be clear, it was not very pronounced, but noticable. It would happen about 75 or 80% of the time. Just a gentle rocking (when at a stop). It seemed that a resonance was actually happening (between engine and car body). If I would just touch the gas pedal to change the rpms even slightly, it would go away. I think the odds of it happening for someone else is slim. Me... I always get stuff like that! Commuter Quote Link to comment Share on other sites More sharing options...
idosubaru Posted June 28, 2005 Author Share Posted June 28, 2005 wouldn't surprise me if that was common. doubt i'll notice though, all my other soobs are XT6's so they make any variety of vibrations/noises depending which one i drive. Quote Link to comment Share on other sites More sharing options...
