xoomer Posted September 15, 2005 Share Posted September 15, 2005 I have no power when going up hills I am also hearing a loud clicking noise on the drivers side. possible coil? bad timing whats up.... also when I try to staRT it takes a few turns and some gas... is my disty screwed.. I followed instructions.. or my coil.. it seems to have a slight miss while ideling./. Quote Link to comment Share on other sites More sharing options...
Turbone Posted September 15, 2005 Share Posted September 15, 2005 Sounds like your timing is off. Do you have a timing light? You also need to connect the green test plugs at the ECU (under the rear dash panel). Slight miss could mean plugs/wires/cap. The clicking could be a CV joint going bad. Quote Link to comment Share on other sites More sharing options...
