mudduck Posted October 13, 2005 Share Posted October 13, 2005 My power steering has become non power steering. It has enough atf . It is real tough to turn the wheel when sitting still or at really slow speed, but above 5 mph or the steering feels normal. Any ideas. Quote Link to comment Share on other sites More sharing options...
nipper Posted October 13, 2005 Share Posted October 13, 2005 could just be the pump is shot, or the rack is shot. the cheap route would be to replace the pump from a junker and see what happens. nipper Quote Link to comment Share on other sites More sharing options...
shortydp45 Posted October 13, 2005 Share Posted October 13, 2005 This happened to me to and one day the hole shaft with pully flew off never to be seen again.Keep in mind i let mine go for atleast 9or10 months. I would sudjest replacing it.I don't know how much $ you have to work with but a new pump (pump only no res. or pully)i was Quoted $125 at the lowest point.Thats in WA. Quote Link to comment Share on other sites More sharing options...
cmiller Posted October 14, 2005 Share Posted October 14, 2005 For about $15 - $25 and a couple of hours of wrenching you can rebuild your PS pump. I bought a new rebuild seal kit from the dealer and a new bearing from McGuire Bearing and now its smooth and doesn't leak believe it or not! I think the most important part to replace is the bearing which also acts a the main seal in the pump. My bearing was shot, rough and loose. Now my steering is like new. Quote Link to comment Share on other sites More sharing options...
mudduck Posted October 14, 2005 Author Share Posted October 14, 2005 Cool, going to try to track one down, or at least see what a pump might cost. It has has a real slow leak for as long as I have had the car. What does it take to rebuild the steering pump? Seems like it would be easy. Quote Link to comment Share on other sites More sharing options...
cmiller Posted October 14, 2005 Share Posted October 14, 2005 Cool, going to try to track one down, or at least see what a pump might cost. It has has a real slow leak for as long as I have had the car. What does it take to rebuild the steering pump? Seems like it would be easy. I just used my Haynes/ Chilton manuals and the diagram from the Subaru dealer, and replaced the seals and bearing and thats it. The Haynes had the best walkthrough for rebuilding the pump. Quote Link to comment Share on other sites More sharing options...
mudduck Posted October 14, 2005 Author Share Posted October 14, 2005 The belt had a little bit of squeeling this morning, but didn't squeel the rest of the day, but I found that it was slipping. Tossed in a new belt this afternoon, and the steering is a whole lot better. The belt must have just been slipping on the pump I guess. Quote Link to comment Share on other sites More sharing options...
