PS hose to interface EA-81 pump to EA82 rack
This is regarding the high pressure hose...
I am having trouble finding a place that can get this to work... I have both hoses, but nobody seems to be able to join them so I have ea-81 pump connnection and a ea-82 rack connection on one hose. Any suggestions? I am in northern colorado if anyone has any first hand experience with a shop that can do this.
Thanks,
Dan
Just use the EA82 PS pump - it bolts right to the EA81 block (same pump used on the EA81T). Then you just have to deal with the belts, which are a lot easier than the hoses. Plus you eliminate the silly idler hanging way down under the engine - no idler at all with the EA82 pump since the alternator takes care of it.
