Guest Meeky Moose Posted July 31, 2003 Share Posted July 31, 2003 anyone know if a AC compressor off a EA82 would fit/work on an EA82T? Quote Link to comment Share on other sites More sharing options...
Guest calebz Posted July 31, 2003 Share Posted July 31, 2003 The compressors should be the same.. the only difference I am aware of is the brackets(not specific to turbo or N/A) there's the facory bracket and the dealer installed bracket.. one has the alt on the left and the compressor on the right the other is opposite. but you can switchthe parts from one bracket to the other with no problems. Quote Link to comment Share on other sites More sharing options...
Guest GlCraigGT Posted July 31, 2003 Share Posted July 31, 2003 Well, I’m aware of 4 different ac systems used on the different ea82 models. The different systems are based on who manufactured the compressor or the compressor location. The different versions are; Hitachi, Nippondenso, Panasonic inboard and Panasonic outboard. The difference between the two Panasonic systems is just the location of the compressor. the good news is that none of the compressor look alike, and the mounting brackets are a little different for each one too. So basically you just need to find a compressor that looks like the one you have and see if it bolts right in. Quote Link to comment Share on other sites More sharing options...
