Minimum clutch thickness
I've never measured overall thickness, but there should be a good 1/16" of material above the heads of the rivets. That's how I usually judge them anyway.
If I had the thing out, I would probably replace the pressure plate and maybe the disc if it was worn down too close to the rivets. I've had a lot of weak pressure plates that don't grab hard enough anymore....
