KRMusher Posted November 20, 2006 Share Posted November 20, 2006 Rear end air bag struts (both) fall over night BUT: last night I put on the raise height switch and they didn't fall! What's going on here?? If I have to replace can you change one end only (rear) over to just springs, as in some posts, or do you need struts? Or do you have to change all 4 if you are converting to non air set up? Any info appreciated!! Only has 84k miles! KRMusher Quote Link to comment Share on other sites More sharing options...
calebz Posted November 20, 2006 Share Posted November 20, 2006 Change all four and get it over with. Air ride is a pain in the rump roast when it gets to be 20 years old, but then again, many things are a pain in the rump roast when they're 20 Just get four Junkyard strut/spring combos from the wrecking yard and slap them in there. Easy. Mine was converted from air ride to standard struts, then to XT6 parts, then to XT6/legacy mix with adjustable coilovers. About to go 100% Impreza/Legacy stuff Quote Link to comment Share on other sites More sharing options...
