Do a search for "rear differential" you'll see some discussions on changing the oil. Seems as if your drive extention of your socket wrench should work fine for the rear, not sure about the front though. Also a good recommendation for the rear is to lossen and remove the top plug first...wouldn't want to drain the oil out from the bottom, only to find the top stuck tight and no way to replace the empty differential.:boohoo:
