chipper6 Posted February 14, 2007 Share Posted February 14, 2007 Hello, I just bought an 89 justy couple weeks ago and just thought I'd see if anyone has had a simular problem with thier cars. When the cars cold its hard to start and does not Idle until its warm then its fine. The engine light was on and the previous owner said it said the Idle up/soleniod valve was actiing up. Stared at the chiltons until I found it and hopefully I can find it when I start to dig in this weekend. Thanks chad Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted February 14, 2007 Share Posted February 14, 2007 First: Welcome! I think it´s due by a Bad Choke, and I think that is Electric. Maybe is just Disconnected, or maybe it has Burned its Resistor. I suggest to Check it Carefully, remove the Air Filter Box, and Start the Engine, at Idle, turn Manually -if you can- the Choke Plate to almost Close, then the Idle shall go up a little. if there isn´t any movement on the Choke when you Start the car cool, that´s the Problem. Good Luck! Quote Link to comment Share on other sites More sharing options...
RONAN Posted February 15, 2007 Share Posted February 15, 2007 Inspect all of the "thousands" :-p of vacuum lines for a leak or leaks. Quote Link to comment Share on other sites More sharing options...
chipper6 Posted February 16, 2007 Author Share Posted February 16, 2007 Thanks I hope I can get in there this weekend and check it out. Quote Link to comment Share on other sites More sharing options...
Esteban32696 Posted February 16, 2007 Share Posted February 16, 2007 Yep, as Ronan said, " check those vacuum lines." My last carbed Justy had a vac line behind the carb that kept coming off . It was very hard to see,,, so every vacuum line on it, follow to make sure both ends are connected & rubber is not rotten. The Justy carb was a complicated, & $$ thing. Once you get it running " pretty good ", you may leave well enough alone.Also, make sure it has a good fuel filter, & run a dose of GOOD carb cleaner thru it. Quote Link to comment Share on other sites More sharing options...
Esteban32696 Posted February 17, 2007 Share Posted February 17, 2007 If you get BRAVE enough to start tearing it down, go here, & print out the pages. http://www.subarujusty.proboards20.com/index.cgi?board=engine&action=display&thread=1171400936 Quote Link to comment Share on other sites More sharing options...
chipper6 Posted February 17, 2007 Author Share Posted February 17, 2007 got in and took a look and it seems that the choke linkage is FUBAR and the choke just flops around like a fish out a water. I held the choke closed and started it and it idled. think the easiest thing to do would be put a manual choke on it. the previous owner said a couple years ago a new carb went on and by the looks of it it looks pretty new. It runs fine once its all warmed up and revs fine just gotta get the choke working. thanks chad Quote Link to comment Share on other sites More sharing options...
#89 Posted February 24, 2007 Share Posted February 24, 2007 chip, One of the JUSTYhedz, 'Scoobaru' just tore down a carb in a seriously surgical way, diagrams, photos everything Chilton didn't bother with and more. I'm trying to find his username on these boards, will send it your way ASAP. Best Luck; Skill, #89 1989 Subaru JUSTY RS 4WD 126, 711 miles Quote Link to comment Share on other sites More sharing options...
