Broken carb mounting stud
There are MANY ways to fix that. Personally, for the time involved, and the nature of aluminum, I would probably just go get another manifold from the JY. At any rate, you should remove the manifold to work on it, and cut off what remains of the stud. Center punch it, and drill the stud out - don't go too deep. Then tap the hole out, and use a bolt instead of a stud to hold the carb down. Or you could put in another stud - up to you.
If any of the stud is sticking out, spray the hell out of it with PB Blaster(or whatever P-oil you use).. let it sit fir a while, then grab the part of the stud thats sticking out with a pair of vise grips. I have done that on a manifold bolt and it worked great
