Anthenium Posted July 3, 2007 Share Posted July 3, 2007 Hey, where does one go to get Bolt-On performance mods for a 1995 - 2003 Legacy/Outback? Just simple stuff like intake, strut-brace, eurothane bushings, etc...(Header/Catback exhaust might be nice too!) And just a HYPOTHETICAL question, but would a 95 Outback use a dry or wet Nitrous system? Thanks, Fat Tony Quote Link to comment Share on other sites More sharing options...
porcupine73 Posted July 3, 2007 Share Posted July 3, 2007 Hi. One place I know of is renickmotorsports.com They're a Subaru dealer in Calif. that has some aftermarket stuff as well. There's other places too... I'm not going to say whether or not it is a good idea to put nitrous on. Just make sure you know if it is legal to have the bottle installed when driving on the street and if there are any insurance implications. I don't like the dry nitrous systems. It relies on the engine running a little rich at WOT to provide the extra gasoline required. I'd go with a wet shot and start with the smallest nitrous jet it has, which would probably be ~30hp. You can tee in the gasoline solenoid into the hose going from the fuel filter to the fuel pipe on the engine. Fuel pressure on these at WOT should be around 40psi or a little more (you need to know the pressure to select the fuel jet). Quote Link to comment Share on other sites More sharing options...
Anthenium Posted July 5, 2007 Author Share Posted July 5, 2007 Hi. One place I know of is renickmotorsports.com They're a Subaru dealer in Calif. that has some aftermarket stuff as well. There's other places too... I'm not going to say whether or not it is a good idea to put nitrous on. Just make sure you know if it is legal to have the bottle installed when driving on the street and if there are any insurance implications. I don't like the dry nitrous systems. It relies on the engine running a little rich at WOT to provide the extra gasoline required. I'd go with a wet shot and start with the smallest nitrous jet it has, which would probably be ~30hp. You can tee in the gasoline solenoid into the hose going from the fuel filter to the fuel pipe on the engine. Fuel pressure on these at WOT should be around 40psi or a little more (you need to know the pressure to select the fuel jet). Thanks, I'll give Renick a peek. Yeah, I'm not looking to NOS my Soobie, but was just curious about Dry vs Wet on this platform in general. BTW, gas milage up to 27 MPG with new Knock Sensor! +3 is good... Fat Tony Quote Link to comment Share on other sites More sharing options...
Virrdog Posted July 9, 2007 Share Posted July 9, 2007 Whiteline is your friend for suspension stuff, if they make it... your car will have real benefit from it. And multi-port wet is the safest bet on NOS. Quote Link to comment Share on other sites More sharing options...
firstwagon Posted July 9, 2007 Share Posted July 9, 2007 Know very little about NOS but for suspension stuff there's a few... http://www.pdm-racing.com/products/subaru_corner.html http://www.boxer4racing.com/ and for info... http://www.legacycentral.org/library.htm Quote Link to comment Share on other sites More sharing options...
