Guest lothar34 Posted August 15, 2003 Share Posted August 15, 2003 97svx posted this: <blockquote><strong><em>Quote:</em></strong><hr>Also check for oil seepage along bottom of timing belt cover. If you see it, point it out and negotiate $$$. The repair is simple at the time of timing belt change. in a different topic. I noticed some oil on the bottom of my timing belt cover when I changed the oil a couple weekends ago. Where does it come from? There were also some grooved rubber seals that weren't seated right. I got them back onto their channel, but I couldn't tell if the oil was coming from behind them or if it was splashing around under the plug (I reused the crush washer -- the car still gave up 4.5 of the 4.7 quarts though). '98 Forester (DOHC 2.5L) I'll try to remember to take a picture this weekend if somebody wants clarification and can help. Quote Link to comment Share on other sites More sharing options...
Guest Setright Posted August 15, 2003 Share Posted August 15, 2003 Likely a camshaft or crankskaft seal. I recommend that you remove the belt cover and find out, and fix it soon. Oil weaken the timing belt and make it break before schedule. Could be a valve cover seal, but there would also be oil along the bottom of the engine. A reused crush washer on the oil pan might cause a drip, but no splashing. Quote Link to comment Share on other sites More sharing options...
Guest 97svx Posted August 15, 2003 Share Posted August 15, 2003 If you are approaching the timing belt service interval, this would be the best time to replace it, along with the cam and crank seals, O-ring behind the oil pump, water pump, thermostat and radiator hoses. Matt Quote Link to comment Share on other sites More sharing options...
Guest kvaleras Posted August 15, 2003 Share Posted August 15, 2003 I had the same problem, oil on the bottom of the t-belt cover, oil pan, cross member. I used the help of people on this forum (Thanks, by the way). Removed t-belt cover and there was good old oil pump giving away oil. So after replacing o-ring, checking the screws on the back of the oil pump (were OK), applying new RTV seal on the back of the pump, and putting the rest back together (took 4 hours, some of it spent just looking at things), no problem so far. I made ~6000 miles, and no leaks. Quote Link to comment Share on other sites More sharing options...
Guest 97svx Posted August 15, 2003 Share Posted August 15, 2003 Yep, my 95 2.2 LS had the same issue, but the water pump was shot at 115k so I did the whole "ball of wax". Sadly, I totalled it 3 days later in an encounter with a NY State DOT snow plow-you know who won. Matt Quote Link to comment Share on other sites More sharing options...
Guest pat1234 Posted August 15, 2003 Share Posted August 15, 2003 I had the same thing happen to my 97 legacy gt in march this year. The leak came out from the bottom of the t-belt cover..... just a few drips here and there. It was the oil pump o-ring that was leaking. Since I was due soon for the t-belt change I changed the o-ring, all cam seals (also prone to leaking some time on the 2.5) and the t-belt as they have to take it off anyways and its cheaper that do it all at once than to do the t-belt months down the road. Cheers Pat Quote Link to comment Share on other sites More sharing options...
