koovle Posted April 9, 2009 Share Posted April 9, 2009 (edited) Hi, this is my first post. I recently got a '92 five speed 4WD loyale and have been giving it the work over. It's running like a dream and I love it, however the instrument cluster lights are not working. The stereo has been ripped out of the dashboard and the clock will come on and off, sometimes really bright, sometimes dim, sometimes not working at all. I would apprieciate any suggestions or help with these problems. The rear wiper isn't working either . . . Edited April 9, 2009 by koovle Quote Link to comment Share on other sites More sharing options...
Cougar Posted April 9, 2009 Share Posted April 9, 2009 Welcome to the forum. I assume you have checked all the fuses under the dash already. I would check to see if the dimmer control is getting voltage next. Quote Link to comment Share on other sites More sharing options...
koovle Posted April 9, 2009 Author Share Posted April 9, 2009 All the fuses look good and will check the dimmer control voltage next. Quote Link to comment Share on other sites More sharing options...
azsubaru Posted April 9, 2009 Share Posted April 9, 2009 RE: Clock problems: Those clocks often have a cold solder joint on the circuit board that causes problems like that. You can usually repair it easily with a solder gun. It's by a resister that gets really hot, not hard to find. Quote Link to comment Share on other sites More sharing options...
ivantruckman Posted April 9, 2009 Share Posted April 9, 2009 Does you heat defrost fan work on all 4 speeds by any chance. these are very common problems on all ea82 Subaru's Quote Link to comment Share on other sites More sharing options...
koovle Posted April 9, 2009 Author Share Posted April 9, 2009 Uh, the heater works in all the fan speeds and positions, the rear defrost works as well . . . should I remove the instrument panel or is there a work around? Quote Link to comment Share on other sites More sharing options...
MilesFox Posted April 10, 2009 Share Posted April 10, 2009 take a look at the dimmer swithc. there are 2 cases that i can account for where the dimmer switch burned out Quote Link to comment Share on other sites More sharing options...
Gloyale Posted April 10, 2009 Share Posted April 10, 2009 take a look at the dimmer swithc. there are 2 cases that i can account for where the dimmer switch burned out +1 on that. Dimmer switch is ussually the culprit if they ALL go out. Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted April 10, 2009 Share Posted April 10, 2009 ...the instrument cluster lights are not working. ... Have you Checked if one of the Headlamps is Dim too? ... if So, your Subie Must have a Bad Relay. One of the Two Headlamps` Relays Control the Dashboard Lights Too, the other Relay Controls the Blue "High Beams" Light at the Dash too. Quote Link to comment Share on other sites More sharing options...
Gloyale Posted April 10, 2009 Share Posted April 10, 2009 Have you Checked if one of the Headlamps is Dim too? ... if So, your Subie Must have a Bad Relay. One of the Two Headlamps` Relays Control the Dashboard Lights Too, the other Relay Controls the Blue "High Beams" Light at the Dash too. A blown fuse will cause the dim headlight as well. but the relay IS a very good place to check. My money is still on the dimmer switch. Quote Link to comment Share on other sites More sharing options...
