Re: 96 EJ22E going turbo and lost
Welcome to the board!
Searching on here for 'swap' and 'conversion' will likely find you a lot of info.
I also know there are dedicated sites for VWs that have swapped in Subaru engines.
Personally, unless you're very familiar w/turbos/wiring/engine management/etc, I'd leave your '96 EJ22E AS IS - don't turbo it. Unless you run <5psi boost, install turbo-quality pistons, and other mods, you'll be looking for a new/replacement engine b4 too long.
Otherwise, find an EJ22T from a '91-94 Legacy or a WRX EJ20 w/all the related bits to go turbo the safe way.
Have fun!
Td
