USFTECH template
Go Back   Ultimate Subaru Message Board > Subarus > Subaru Modifications > Subaru Retrofitting
Reply
Thread Tools Display Modes
  #1
Old 07-19-2010, 10:25 PM
Marter_Templar Marter_Templar is offline
New User
City: São Paulo - Brazil
Ej18 with EJ20 Pistons and rods, its possible?
Hello again, i have troubles with my GC6 and i have to change the pistons and the rods of the EJ18, so i bought the EJ20 pistons and rods to install on the OEM EJ18E block, can i bore the EJ18 to 92mm? i need to know if this will be possible, and if i have to change the sleeves of the cilinder to, ty for attention and sry for my bad english.
  #2
Old 07-20-2010, 04:27 AM
LPGsuperchargedBrumby LPGsuperchargedBrumby is offline
Subaru Nut
City: Dunedin, NZ
Re: Ej18 witch EJ20 Pistons and rods, its possible?
you would probably have to resleeve it i would think...might be easyer to get a EJ20 and swap your heads and intake manifold onto it...lol plus you would get a high compression motor because the EJ18 has a smaller head volume than a EJ20....high compo= good for alcohol blend fuels you guys get in brazil
  #3
Old 07-20-2010, 09:36 AM
LeoneTurbo's Avatar
LeoneTurbo LeoneTurbo is offline
USMB Regular
City: Arnhem (The Netherlands)
Yep as he says. The liners are only 4-5 mm thick so if you want to go from 87.9 to 92.0 you'll end up with only 2 mm thick cylinder walls - which is very good for cooling but a lot less for reliability!
  #4
Old 07-20-2010, 10:37 AM
New User
Quote:
yep, but here in brazil its to expensive to get an EJ20 Shortblock, and its much more cheaper to bore the EJ18, i will take some like 10,5:1 of compression with the EJ20 pistons and the EJ18 headers , i will look for the sleeves here in Brazil, tks for helping.
Quote:
hummmm, so the EJ18 sleeves can hold the EJ20 pistons ? the car will stay original i am not thinking to put an turbo in it...ty for help
  #5
Old 07-20-2010, 09:10 PM
Gloyale Gloyale is offline
Elite Master of the Subaru
City: Corvallis, OR PNW
Re: Ej18 with EJ20 Pistons and rods, its possible?
If you aren't turboing, then why the EJ20 pistons?
You should return them and get some standard EJ18 pistons.
And just for the record, what are you doing to the poor N/A EJ 18 that you need to replace pistons and rods? Rods could be from lack of oil changes, but why would you need new pistons. If anything ReRing the ones you got and slap some new bearings in and go.
Trying to use ej20 pistons seems pointless.
  #6
Old 07-20-2010, 09:41 PM
New User
its not pointless, 1800cc its less than 2.000cc , with this simple "change" my car will gain some close to 15hp , i will have more compression ratio to use Etanol, so with the 200cc more and the 1~1,5 more of compression ratio (because i will keep the stock ej18 headers) , i wiil have an motor from 105 hp stock to 125~130 hp with etanol.
  #7
Old 07-21-2010, 01:57 AM
rxleone's Avatar
rxleone rxleone is offline
Eat, Live, Breath Subaru
City: Blenheim, New Zealand
Quote:
Simple? Boring two or three mils out of an engine block isn't very simple. It won't be simple to fix when it grenades because the sleeves are too thin. Import a used EJ20 block. It'd cost you less in the long run.
Also - I wouldn't even bother splitting a block to gain 15HP. Why not just slap a turbo on it?
  #8
Old 07-21-2010, 02:41 AM
LeoneTurbo's Avatar
USMB Regular
In that case why not source a complete EJ22 longblock and swap it in? No wiring issues etcetera and 30 hp gain over stock.
  #9
Old 07-21-2010, 10:09 AM
New User
the only problem of installing turbo is that in Brazil the law doesnt allow it, i am thinking on getting the EJ20T forjed short block and putting all other pieces of my EJ18 Headers, air intake , ECU, etc..., do u think my original EJ18 ECU can manage that change? , tks
Its to hard to find a complete EJ22 here, i thinking to get a EJ20T forjed short block that are selling here in Brazil, do u think the original ej18 ECU will handle that system? tks
  #10
Old 07-21-2010, 10:49 AM
Sooooooo much work and really you won't notice any difference when driving it.
Oh yeah, until it blows.
Honestly I don't even think there is enough material to bore out, the limit listed by FHI is .50mm so this is all an irrelavant discussion.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
EJ22T crankshaft, rods, pistons. blackbart Subaru Part/Stuff For Sale 4 01-14-2010 12:53 PM
Forged Rods & Pistons subpilot Older Generation of Subarus: 80's/XT/Loyales... 8 08-18-2006 06:24 PM
Performance rings, pistons, and con rods... Subarutex Older Generation of Subarus: 80's/XT/Loyales... 10 04-07-2005 04:57 PM
FS: EA82T pistons/rods/crank/block... WJM Subaru Part/Stuff For Sale 0 01-30-2005 03:57 PM
EJ18 pistons svxpert Older Generation of Subarus: 80's/XT/Loyales... 4 08-25-2003 12:14 AM
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright (C) 1997-2008 Ultimate Subaru Club, All Rights Reserved
test
