USFTECH template
  #1
Old 12-21-2005, 12:21 PM
doogymon doogymon is offline
New User
City: Toronto
Thumbs up Re-visit EJ25 replacement with EJ22
Great Site
Disclaimer: Haven't played with cars for a lonnnng time and I know this site has alot of threads about this subject. Sorry for any redundancy or improper terminology.
Finally got me a Subaru (been test driving for 8 years). 1997 Outback LTD 2.5L , 300k KM and pooched Head Gasket. I have placed a deposit on a 1995 EJ22 with 93k Km and will pay the rest as soon I have a warm and fuzzy confirmation that I can plug the 2.2L into the O/B.
Is it possible for some "corrective" comments on some of the variables/concepts listed below:
1. The 2.2L (EJ 22) must be a 1995 for a Transplant into a 1997 O/B because of the number of Tranny Bolts? i.e. Post 95 EJ22s went to 8 bolts?
2. The 2.2L must be a 1995 for a transplant into a 1997 O/B because the 95 2.2L has a dual Output Exhaust Manifold that will match up with the 97 Y pipe. Other years for the EJ22 did not have dual exhaust port.Therefore I also need the 95 2.2L exhaust manifold which is included with the EJ22 on hold.
3. The onboard 97 O/B ECU (OBD2) can remain and will plug and play with the 95 2.2L which is OBD2.
4. The 97 O/B is an Automatic Tranny. The 95 2.2L engine Tranny is unknown. I don't think this is an issue.
5. Would it be smart to change the timing belt, water pump and oil seals with the replacement EJ22 before I attempt to stick it in the car?
6. I think I saw a thread where a Suby Guru listed misc items to consider for a job like this like. He talked about engine mount rubbers and stuff like that. Any
ideas?
Thanks Subies. Thanks Emily
Really appreciate it
Merry Xmas from Doogymon
  #2
Old 12-21-2005, 07:39 PM
lmdew lmdew is offline
Subaru Master
City: Colorado Springs
Re: Re-visit EJ25 replacement with EJ22
I've done two of these 98 Legacy Outback 2.5 swapped to a 2.2 from a 95. Both were Outbacks had standard transimssions so I had good performance with the 2.2.
Yes, the 95 2.2 is a direct plug in. If you swap over the flex plate from your engine, that will bolt up to the transmission fine. Make sure you do NOT pull the torque convertor out of the trans at ALL. Keep it fully engaged back into the trans when you pull the engine.
I also pulled the vapor canster from the 95. The 97-98 has it in the tank area, but you can add the one up front and then you only have one vac. line to plug.
If you know the engine is good, I'd do the T-belt and water pump up front. If you think it may need other work, just put it in and make sure it works before you put any more money into it. Its not hard to do those items with the engine installed.
Good Luck
  #3
Old 12-21-2005, 08:48 PM
99obw's Avatar
99obw 99obw is offline
this space for rent
City: Ithaca area
I have done this swap as well(not to our car). It can be done using the vapor canister in the rear with only mild futzing with the vacuum lines.
  #4
Old 12-21-2005, 09:20 PM
Gnuman's Avatar
Gnuman Gnuman is offline
1000+ Super USER!
City: Bethel Island, CA
1 is false, 2 is true, 3 is true, 4 should not be an issue, 5:
If you got the engine from Emily, talk to her about the timing belt. CCR is a very reputable company. They may have put one on for you, but I cannot even begin to speak for them. That may be in the area that they do not touch as the belt to use varies from state to state.
  #5
Old 12-30-2005, 07:18 PM
New User
City: Toronto
Thanks very much for your replies.
I will be elbows deep in a few weeks with changing the engine on my 97 OBW.
I may be popping in for a few questions so I thank you in advance.
Happy New Year
  #6
Old 12-31-2005, 12:42 PM
grossgary grossgary is offline
Elite Master of the Subaru
City: WV
i may be doing the same and have looked around and posted here before about this.
other era 2.2's can be used, doesn't have to be a 95. if you do, you'll have to swap the exhaust manifold as well. keep the 2.2 manifold with the 2.2 motor if it's not a '95. i have a '97 and '98 2.2 that i may be swapping into a 2.5. they will plug and play as well just like the '95.
__________________
88 XT6 Lifted FT4WD, 88 XT6 Manual, 89 XT6 FT4WD, 87.5 XT deturbo'ed
02 OBW VDC H6
96 Leg LSi castrated to EJ18 & FWD
  #7
Old 12-31-2005, 12:46 PM
99obw's Avatar
this space for rent
City: Ithaca area
Do the '97 and '98 have EGR?
  #8
Old 12-31-2005, 01:45 PM
avk avk is offline
Certified Subaru Nut
City: NJ
To have an EGR valve, the 2.2l needs to be from 1995 or later (but still phase I) car with auto transmission .
  #9
Old 01-01-2006, 06:38 AM
pearlm30's Avatar
pearlm30 pearlm30 is offline
Eat, Live, Breath Subaru
City: Tampa, FL/ Bethlehem, PA
It will be nice for someone to document( step by step with photos ) the whole swap.
  #10
Old 01-01-2006, 09:30 AM
ccrinc ccrinc is offline
The Subaru Whisperer
City: Denver, CO
There is indeed one issue about swapping an EJ22 into a later model Outback.
In mid-'98, the bell housings on both the transmission and engine went from a 4 bolt to an 8 bolt pattern. So, if you try to put a '95 EJ22 into a '99 Outback (for instance) you do not have enough bolt holes to bolt up the starter.
Drilling an additional hole in the 4 bolt EJ22 is iffy at best, unless it's being done by one very precision drilling master.
After 5/98, there may be issues with sensors, OBDs, ECU, etc. Not enough swaps in that time range to have documented everything.
Emily
http://www.ccrengines.com
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
IT'S DONE! Swapped EJ22 for EJ25 in '97 Outback kaltree New Gen Subarus: Legacy to Current Models 131 08-31-2010 07:55 PM
96 OBW EJ22 / EJ25 swap garrymcm Subaru Retrofitting 0 11-02-2005 08:26 PM
EJ22 vs. EJ25 LosDiosDeVerde86 New Gen Subarus: Legacy to Current Models 3 08-04-2005 03:39 PM
WTB: EJ22 or EJ25 complete engine slidewaysuby Subaru Part/Stuff For Sale 5 05-19-2005 09:11 PM
Difference between ej22 mt and ej25 mt? simpreza2 New Gen Subarus: Legacy to Current Models 5 02-27-2005 07:23 PM
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright (C) 1997-2008 Ultimate Subaru Club, All Rights Reserved
test
