namotco Posted January 30, 2004 Share Posted January 30, 2004 I have a 93 legacy L, here's the symptoms: 1. slow to turn over in cold 2. Check Engine Light has been coming on and off periodically for 6 months, usually either when I start or a mile or 2 after that (typically only for a minute or so). Seems to run fine, but I've now noticed that when it goes off, it accelerates just slightly for a second. 3. more recently I've noticed that when driving on the highway it doesn't seem to reach 4th gear (or the highest one...) as easily as it used to. At first I thought it was just cold, but on a recent long trip it the RPMs stayed around 3 instead of the usual 2-2.5 and I went through more gasoline (2/3 tank instead 1/2 as usaul). 4. a few months ago I noticed the "D" light doesn't come on, but the others do [PRND321]. I thought this could just be a burnt-out LED since it is 10 years old, but someone suggested that it could be the ECM with the above. I think that's it... Here's what I've done over the summer: new spark plugs (not wires), air filter, PCV, did a partial change of transmission (ATF- Valvoline higher milage) (didn't chage filter because I didn't know it existed), did differential gears, changed the wheel bearings (front), and I've been using synthetic oil Any ideas? Quote Link to comment Share on other sites More sharing options...
Subie Gal Posted January 30, 2004 Share Posted January 30, 2004 have you pulled the code for the repeated check engine light? i suggest you get that code.... and likely the source of you issues can be unearthed.... Jamie Quote Link to comment Share on other sites More sharing options...
