Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
Strange Oil leak.
#1
Posted 20 September 2009 - 02:57 AM
My 94 legacy ts-r just started leaking oil pretty bad.
Bit of a wiered leak though. seems only to leak when the oil is hot. leaking rate is a 10cm accross puddle, in about half an hour. doesnt seem to leak once oil has cooled again.
had a look underneath and it seems to be coming out the right hand side of the timing belt cover.
I took the cover off, and there wasnt any oil spattered around inside the cover, so think it must be coming out of the head.
wiped the head down to try and see where its coming from, doesn't seem to be coming out the bottom of the gasket, but rather a point i cant see maybe half way up the head. (hard to say, cant find a photo on the net)
any bolts up there that could've come loose? Or other thaughts on where it could be coming from?
Cheers
Tim.
#2
Posted 20 September 2009 - 08:56 AM
most folks, and wise/honest mechanics, consider it the best idea to do a timing belt and reseal the entire front of the engine on a car this old.
timing belt and all the pulleys
cams seals, cam orings
oil pump seals, crank seal
all of that resides behind the timing belt, so best to do all in one shot.
silly to replace just one seal, then 6 months later one of the others starts leaking.
Use Subaru seals for all of those, they are higher quality.
#3
Posted 20 September 2009 - 09:25 AM
#4
Posted 20 September 2009 - 10:12 PM
#5
Posted 21 September 2009 - 03:07 AM
Thanks for the help.
Is there any way of knowing whether its a camshaft or crankshaft seal that needs replacing before taking it to bits? or is it just more likely to be camshaft?
just had Cambelt done very recently, Damn!
Here's a pic i found, to help me ask questions about the work.
[url]http://www.main.experiencetherave.com/subaru/images/timingbelt/DCP_2705.JPG[/url]
(Thanks heaps for the pic!!!!)
OK, so if its a camshaft seal leaking, i will need to take off the sproket where the wrench is, and the seal will be behind that.... this is the side the leak is dripping down too.
Are there 2 camseals- 1 on either side?
If its the crankshaft seal leaking, i will need to fix the seal behind the crankshaft sproket (little one under the belt in the middle).
Any tricks to getting the sprockets off without specialized (chainwrench etc..) tools??
anything else to know?
Guess it'll all make sense when i get in there and have a proper look!
Cheers
Tim
#6
Posted 21 September 2009 - 07:51 AM
yes, i already did that for you based on what you said here:Is there any way of knowing whether its a camshaft or crankshaft
in a sense it really doesn't matter though because you'll want to replace it all, they're over 15 years old. If one started leaking there's a good chance another one might some time soon too. It's kind of silly to take it all apart and skip replacing a $5 seal......
Actually you already know what I'm talking about:
so why just replace one seal, only to have another start leaking and have to do it again?
2 cam seals and 2 cam orings - replace them all.Are there 2 camseals- 1 on either side?
Yes, crank seal is part of the oil pump behind the crank pulley and sprockets.
Most folks on here reseal the oil pump while it's staring them in the face rather than just replace the crank seal.
the cam sprocket bolts are TIGHT AS ALL GET OUT. i loosen them before taking the belt off. otherwise they're a pain - but rubber strap wrenches, chain wrenches (with suitable rubber to protect the gears) work too.Any tricks to getting the sprockets off without specialized (chainwrench etc..) tools??
i've heard there are indentations on the cams themselves that a wrench slides right on to hold them in place, so you could pull the valve cover and do that as well, that would be an easier way to do it.
these motors are so reliable and easy to maintain that in some sense it's a really good idea to just replace everything now. good chance you can run this thing another 120,000 miles by just replacing the timing belt at 60k without any other problems if you do a good job now.
#7
Posted 21 September 2009 - 11:12 AM
Sadly, this is only on the 2.5 engines:-\
For a 2.2 you really almost have to use a GOOD strap wrench or a proper Cam tool.
#8
Posted 22 September 2009 - 10:24 AM
Also inspect the end of the spark plug wires to see if there is any oil on them.
nipper
#9
Posted 22 September 2009 - 01:04 PM
Do all the front seals, main, cam and reseal the oil pump. If you dont do all of them, as soon as you get it all back together Mr Murphy will show up.
nipper
94 2.2 valve covers are not like the newer 2.2L or the 2.5's.
