BRATDUDE Posted September 21, 2009 Share Posted September 21, 2009 I HAVE A 2003 FORESTER. aLL ALL FORESTER EQUIPPED WITH THE KEYLESS ENTRY, EVEN THOUGH YOU DO NOT GET THE REMOTE IN THE X MODELS? IF NO WHERE ON THE CAR IS THE KEYLESS SYSTEM TO SEE IF MY CAR IS SET UP FOR THE KEYLESS ENTRY, BEFORE I PURCHASE A NEW REMOTE. Quote Link to comment Share on other sites More sharing options...
RAYJAY Posted September 21, 2009 Share Posted September 21, 2009 http://www.cars101.com/subaru/forester/forester2003.html 03 was a major make-over for the Forester a few things new on all models All new Dashboard All new Center console re-designed with 2 cupholders Hill holder clutch is back! (manual only) Side airbags standard on all models Dual stage deployment front passenger airbag Aluminum alloy hood (lighter weight) Aluminum alloy rear gate (lighter weight) Counter balanced glove box (easier open) Dual vanity mirrors Dual overhead console bins Fuel door release lever Larger disc brakes Illuminated power window switches Accessory plug in console plus dash lighter plug Re-designed driver's seat with greater height adjustment range Tilt wheel has larger range No passenger door key, key works on driver's door only (and remote entry is std on all models) new on X (only $250 more than 02 L) X model replaces L 16" wheels (were 15") Keyless remote standard (was optional) Variable delay front wipers (replaces single speed) Rear window wiper de-icer CD player/AM/FM/Weatherband standard (no cassette avail) Quote Link to comment Share on other sites More sharing options...
BRATDUDE Posted September 21, 2009 Author Share Posted September 21, 2009 Wow! Thanks for all that info. I am sure i will need it. Quote Link to comment Share on other sites More sharing options...
BRATDUDE Posted September 22, 2009 Author Share Posted September 22, 2009 ok, i have a remote, when i follow the instructions, about turning the switch from off to on 10 times, the horn does not sound. i have tried it several time even a few more time waiting for the horn to work, nothing. i did notice when i manuall locked the doors, with the door lock, when closing the door i heard a mild chirp and the park lights flashed. i just cannot the horn to sound when turning the switch. any suggestions, or what am i doing wrong. Quote Link to comment Share on other sites More sharing options...
BRATDUDE Posted September 23, 2009 Author Share Posted September 23, 2009 Would these systems be set up under a fuse to where it would not make the horn sound. I cannot get the system to work. Any help would be great. Quote Link to comment Share on other sites More sharing options...
RAYJAY Posted September 23, 2009 Share Posted September 23, 2009 Would these systems be set up under a fuse to where it would not make the horn sound. I cannot get the system to work. Any help would be great. try here http://www.cars101.com/subaru/keyless.html Quote Link to comment Share on other sites More sharing options...
BRATDUDE Posted September 24, 2009 Author Share Posted September 24, 2009 you know, it would help if i would read all the directions, i was no depressing the brake when it tried this before. retired it and guess what, works like a charm. thanks everyone for the help. Quote Link to comment Share on other sites More sharing options...
