the f bomb Posted September 23, 2009 Share Posted September 23, 2009 from searching around, the likley culprit seems to be the horn relay- anyone know where this is exactly or have a wiring diagram? 91 legacy wagon. i've checked all fuses, grounds, cruise switch, horn switch, the cruise diaphram holds vacuum, etc. any ideas? thanks Quote Link to comment Share on other sites More sharing options...
idosubaru Posted September 23, 2009 Share Posted September 23, 2009 what kind of car? year, make, model, trans, etc? have you checked the fuses? if the cruise control switches are on the steering wheel then i'd guess the connector behind the steering wheel. but i don't think many (or any) EJ's have them on the steering wheel. Quote Link to comment Share on other sites More sharing options...
Cougar Posted September 23, 2009 Share Posted September 23, 2009 A common trouble with cruise control systems is the disconnect switches on the brake and clutch pedals aren't adjusted correctly. The system thinks the pedal is depressed and the switch is closed. For the horn problem see if tieing power directly to the horn will make it work. It may be bad. If that is ok then look for the relay under the dash. Quote Link to comment Share on other sites More sharing options...
OB99W Posted September 23, 2009 Share Posted September 23, 2009 Clockspring? Quote Link to comment Share on other sites More sharing options...
davebugs Posted September 23, 2009 Share Posted September 23, 2009 Clockspring? Gets my vote since both don't work. If the car had airbags that light would probably be on as well. Quote Link to comment Share on other sites More sharing options...
