Radio fix on the cheap?
7 replies to this topic
#1 FlyB0y
FlyB0y
    Apprentice to Subie Gurus
  • 911 posts
  • Oregon City
Posted 24 September 2009 - 02:11 AM
Ok, I found 2 possible items on a thread from 2006, I have engine noise interfering with the AM reception on my stock radio. Some say just put in some shielded speaker wires, others talk about a ground wire for the ignition coil?
This has only started happening recently, and I haven't done anything with my coil, but I have been messing around with my dual battery set-up.
I know these are cheap radios, but I like the look of the stocker in my dash :).
Any other suggestions?
Thanks!
:banana:
#2 Niku-Sama
Niku-Sama
    Subaru Fanatic!
  • 381 posts
  • Lesser Up North
Posted 24 September 2009 - 03:52 AM
generally theres a filter of sorts on the alternator, mabe its gone bad?
#3 Mykeys Toy
Mykeys Toy
    Subaru Master
  • 2,089 posts
  • South Prairie, Wa
Posted 24 September 2009 - 06:22 AM
Check the battery, body and engine grounds make sure they are good as well as tight. Are you running the batteries in parallel or did you use a isolator? I think for radio feedback with an isolator you should run another body ground.. I am just taking a stab at this since I never had feedback unless I ran power wire too close to speaker wires and patch cables.
Mike
#4 bheinen74
bheinen74
    Banned
  • Banned
  • Pip
  • 0 posts
  • central Iowa
Posted 24 September 2009 - 08:07 AM
dual battery setup? How to fix your problem cheap.
Get rid of that extra battery. Sell your extra battery for like 30 bucks cheap. This will fix your problem and you will have extra money in your pocket. Put it back to stock, way, and you won't have a problem.
Edited by bheinen74, 24 September 2009 - 10:31 AM.
#5 GeneralDisorder
GeneralDisorder
    Elite Master of the Subaru
  • 21,690 posts
  • Portland
Posted 24 September 2009 - 10:04 AM
Subaru's don't have filters on the alternator, although it is possible to install one. You should have a noise filtering capacitor on the igntion coil - look for a black wire running to a small metal cylinder - the other end of the cylinder will be another black wire running to a chassis ground. The wires are often broken at the cap, or the entire cap is just missing because people don't know what they do and when the car seemingly has not ill effects from it being broken or disconnected they are tossed.
You may want to get a cap filter for the alt as well.
#6 Cougar
Cougar
  • 6,563 posts
  • Anchorage
Posted 24 September 2009 - 10:30 AM
It would be nice to know what kind of noise you are picking up. Alternator noise makes a kind of whining noise and ignition noise is a pulsing type noise. A lot of times this problem can be solved by cleaning the ground connection of the antenna to the chassis of the car. Bad grounding is the first thing that should be looked at for this kind of thing in my book. Without a good ground connection the antenna lead shielding can't do its' job.
#7 FlyB0y
FlyB0y
  • 911 posts
  • Oregon City
Posted 24 September 2009 - 12:59 PM
Thanks all for the info! :clap:
As for the sound, it's probably alternator, since it is directly related to the RPM's of the engine and the noise increases as engine RPM increases.
As for the dual battery, I have it running in parallel, but it also has an isolation switch in-case I want to run one battery down while parked, so that the isolated one will still be there to start up the engine.
I have had the dual battery system for years with no problems, only recently I removed the secondary one to put in a trailer to power my electric bike project.
I will see if that ground is needing attention. zzz
#8 bheinen74
bheinen74
    Banned
  • Banned
  • Pip
  • 0 posts
  • central Iowa
Posted 24 September 2009 - 01:14 PM
the shorter the length of the ground cable the better.
