RAugur33 Posted September 24, 2009 Share Posted September 24, 2009 Bill, I sent you a PM awhile ago about buying a set of your 4" strut blocks. Quote Link to comment Share on other sites More sharing options...
The Beast I Drive Posted September 25, 2009 Share Posted September 25, 2009 Checking Pm's... Ill be making some strut blocks this weekend to pass the time while I wait for Earl to come up... 4" for EA82? Or EA81? I keep forgetting which one it is... Also, anyone else interested in camber correct, 1/4 thick steel, strut blocks, please let me know ASAP and I will try to get them all done this weekend, just let me know if they are for EA71/EA81, or EA82. They will be $40 a pair no matter what size. Thanks, and sorry RAugur, Ive been dragging my feet on this really bad and Im sorry if I've irritated or frustrated you in any way... -Bill Quote Link to comment Share on other sites More sharing options...
RAugur33 Posted September 25, 2009 Author Share Posted September 25, 2009 I need the 4" strut blocks for an EA81. Your blocks correct for camber, right? I am definitely irritated and frustrated, but it has nothing to do with you:grin: Quote Link to comment Share on other sites More sharing options...
The Beast I Drive Posted September 25, 2009 Share Posted September 25, 2009 I need the 4" strut blocks for an EA81. Your blocks correct for camber, right? I am definitely irritated and frustrated, but it has nothing to do with you:grin: I do compensate for camber, so it should all line up like stock for the EA81's though you will have to do a little hammer work on the inside of the strut towers, there just isnt any way around this... On the EA82's there is more clearance in the strut towers and hammering is not required... -Bill Quote Link to comment Share on other sites More sharing options...
michael appel Posted September 28, 2009 Share Posted September 28, 2009 what degree does it have to be for the ea 82 Quote Link to comment Share on other sites More sharing options...
The Beast I Drive Posted September 28, 2009 Share Posted September 28, 2009 what degree does it have to be for the ea 82 Depends on what kind of lift you have. If you have the struts and crossmembers lifted the same amount, you need 12-23 degrees, but if you go 1-2" higher on the struts, you need 15-16 degrees or so. -Bill Quote Link to comment Share on other sites More sharing options...
RAugur33 Posted September 28, 2009 Author Share Posted September 28, 2009 for the EA81's though you will have to do a little hammer work on the inside of the strut towers, there just isnt any way around this... So, how much hammering needs to be done on the EA81? Were you able to make a set this weekend? Quote Link to comment Share on other sites More sharing options...
The Beast I Drive Posted September 28, 2009 Share Posted September 28, 2009 I was able to get started, but we had a major equipment failure (read: Burned to the ground) at work.... So I had to tend to that -Bill Quote Link to comment Share on other sites More sharing options...
michael appel Posted September 28, 2009 Share Posted September 28, 2009 4 inch on the ea82 what is the degree angle or could I lengthen the arm on the bottom Quote Link to comment Share on other sites More sharing options...
The Beast I Drive Posted September 28, 2009 Share Posted September 28, 2009 If you have 4" strut blocks and 4" crossmember blocks, then you should do anout 12 degrees. Its easier than lengthening the control arms... -Bill Quote Link to comment Share on other sites More sharing options...
michael appel Posted October 1, 2009 Share Posted October 1, 2009 totally show me a picture of them done I think I got it but Im not sure what it should look like Quote Link to comment Share on other sites More sharing options...
