Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
rear hatch wiring issue>97 impreza outback
#1
Posted 30 September 2009 - 04:47 PM
No rear defrost
No 3rd brake light
No rear wiper motor.
Those 3, all part of the hatch, do not work.
Everything up front checks good, fuses/relays/wiring
I trace it to a single blue 12v5b-1t 5 prong relay underneath the passenger side tail light(inside)
Turn the rear wiper on, single click, then nothing.
Pulled the relay, appears to be ok, dont have specific ratings to test this one out at, never seen one like it before.
So, I am curious,
Anyone have this thing happen before? If so, how did you solve it? Am I on the right track with this relay....?
From what I gather this is the rear wiper relay, however, would it also wipe out defrost and 3rd brake?
any info would be greatly appreciated!
#2
Posted 30 September 2009 - 05:26 PM
nipper
#3
Posted 30 September 2009 - 05:41 PM
#4
Posted 30 September 2009 - 06:02 PM
#5
Posted 30 September 2009 - 06:12 PM
pop the hatch, you'll see on the passengers side upper corner a rubber hose connecting hatch to body. inside of there you'll find cut wires. they need repaired. not much room to work with and it's annoying how many wires there are, so if you don't feel comfortable doing it get someone to fix it for you. you'll likely have quite a few cut or with bare metal showing.
that was one thing i was thinking.
there is a semi-pinch point right there, i just didnt get to look at it this afternoon.
i despise wires in small places too!
ill inform of the news tomorrow, when it is daylight again!
Thanks guys.
by the by,
Im steve, have a 98 legacy outback, and a 97 impreza outback.
Former Mk2/mk2 VW junkie/techie.
needed something with AWD, and with a "touch" more reliability...go through 17 VWs in 10 yrs.......
#6
Posted 30 September 2009 - 09:21 PM
the impreza engine and trans has the ability to outlast your willingness to keep doing this kind of maintenance on it. that EJ22 and trans can last a REALLY long time if you keep up with maintenance and minor glitches like this. It wasn't hard at all (I just did this over the summer to ours before we sold it to a friend), just took time and make sure none of your wires "fall" down to places you can't get. The body side doesn't have much room to play with...although if you were adventurous you might find an access point inside by removing some interior trim, don't know.needed something with AWD, and with a "touch" more reliability...
good luck.
#7
Posted 01 October 2009 - 08:44 AM
A bad piece of design since I couldn't see any fix other than to splice and insulate. There should be the ability to replace the harness in its entirety, but I don't see that as a possibility.
#8
Posted 01 October 2009 - 08:49 AM
I did this recently on my '97 Impreza when the rear lock no longer worked. Everyone who posted about looking under the rubber boot in the upper rear corner was right on the money. In addition to that I found a total of 7 wires already cut and a few more about to go.
A poor design area for sure. Especially since you can't "pull" enough out of the interior compartment to make a good repair. I ended up splicing every wire twice in an attempt to "push" the first splice into the headliner so that it wasn't a flex worry, and have the second splice in the hatch for protection.
#9
Posted 01 October 2009 - 08:57 AM
Yes, it's a bad design, but the only one available I think. BTW, just the other day a Cadillac came into our shop with the driver door control pod switches not working for the window control, guess what, broken wire in the rubber accordian from the body to the door, fix time-10 minutes. Our mechanic knows where to look.
#10
Posted 01 October 2009 - 09:14 AM
http://opposedforces...illustration_1/
#11
Posted 01 October 2009 - 09:46 AM
I can't tell from the Legacy illustration for sure where they go on the Legacy - it looked more to me like they went down the drivers post. But I could easily be wrong.
But on the Legacy drawing it looks like the wires to the hatch come out the other side (Passenger side) and I believe they were on the Drivers on the one that I had to fix.
#12
Posted 01 October 2009 - 01:00 PM
On my Impreza the rubber booty was on the right (passenger) side of the car. Worst problem is that unless you remove all the connectors at the end of the cable (near the tail-light assembly) you can't pull the cable back up the hatch pillar (or get it back in after you've made the repair). I dread having to go back in there again later the next time one or more wires break.I believe the OP was for an Impreza and the wires come out at the top on the drivers side at the hatch.
#13
Posted 01 October 2009 - 03:13 PM
someone cut the string of wires going into the hatch, at the joint. nice, clean cut.
going to repair now.
#14
Posted 01 October 2009 - 04:09 PM
#15
Posted 01 October 2009 - 04:43 PM
#16
Posted 01 October 2009 - 05:58 PM
It really looked like someone got angry with the original owner, took some dykes to the wires, snip snip...no more rear power.
Had to remove all the inside plastic trim from center roof through passenger side wheel well.
pulled wires back through, snipped em, and put butt connectors on
ran em back up, crimped the wiring. slid boot back into place, and bingo.
